Go Back   Train Horn Forums > Main > Train Horns
 Register
Reply
Thread Tools Display Modes
  #1
Old 17th June 2010
gary:) gary:) is offline
Junior Member
gary:) is on a distinguished road
Default Stebel air horns
Are these loud??? any good???
This is my 1st "train" setup im doing. i brought the set and cant wait to get them but just thort i would ask the experts
there are 5horns in the kit! and has it own compressor pump. tho i will be useing a air tank to power them.
Hear is the link from ebay have a read
http://cgi.ebay.co.uk/ws/eBayISAPI.d...id=p2761.l1259
  #2
Old 17th June 2010
Bryan Bryan is offline
Master of Scares
Bryan is on a distinguished road
Send a message via Skype™ to Bryan
Default
Never heard of them, youtube have some vids but they dont sound to nice.
__________________
1994 GMC Sierra 1500
5.7L V8
Nathan AirChime K5LA
Graham White E-Bell
12 Gallon Tank
Dual Viair 444c
Hornblasters 100W PA/Siren
Watch my Vids on YOUTUBE
See my Install HERE.
  #3
Old 17th June 2010
avfrog's Avatar
avfrog avfrog is offline
Conductor
avfrog is on a distinguished road
Default
A rule of thumb... If there is no tank, then it's no good.
__________________
2006 F150 - Nathan Airchime K5HA (modified)
7 gallon tank, DC5000 compressor, GC Xtreme 350 3/4" valve, 5/8" ID air line, viair 110/145
K5HA short burst
K5HA sound delay
K3LA video
  #4
Old 18th June 2010
Junior Member
Default
Quote:
Even if you add your own air tank?
  #5
Old 18th June 2010
BigYela's Avatar
BigYela BigYela is offline
Conductor
BigYela is on a distinguished road
Default
I don't mean to burst your bubble, but you'll need to check if that compressor will even handle filling a tank. It may burn it up if it can't handle running for long periods of time to fill a tank or if it can't block any back pressure.
__________________
Jeff
K5LA @ 200psi / Dual 444Cs / 12 gallon tank / Manual train horn valve & a 1/2" solenoid valve for honking / 1/2" solenoid drain valve for dumping moisture / Black AZ digital air pressure gauge / 1/2" tubing
  #6
Old 18th June 2010
BigYela's Avatar
Conductor
Default
Also the horns probably won't handle a very high PSI, so be careful if you do add a tank that you also regulate the PSI down to whatever those horns will handle or it will blow them apart.
__________________
Jeff
  #7
Old 18th June 2010
Junior Member
Default
Jeff cheers for you reply, i wont be useing the compressor to fill my tank im useing a diving tank witch is filled to 4500 psi and i will be getting it filled at a dive shop
I will also check for what the horns are rated too when i get them, but i have other horns on the way i also brought the guild to build air horns from pvc seems pretty dam good.
  #8
Old 19th June 2010
djQUAN djQUAN is offline
Conductor
djQUAN is on a distinguished road
Send a message via Yahoo to djQUAN
Default
just to give you an idea, horns with tanks run at about 120psi and above.
horns with on-demand compressors like that run at 7psi.
I have tried similar horns like that and ran them on a 125psi tank. they do sound very loud. much louder than the stock compressor but the hose keeps popping out. didn't bother experimenting any further than that.
__________________
2004 Toyota Rav4
Viair 400C
2gal surplus truck air brake tank
Custom Electronic pressure switch at 130psi
Three chime Semi horns for daily driving
Shocker XL for playtime
  #9
Old 19th June 2010
Junior Member
Default
Cheers these are my 1st horns, have been seraching on ebay for ages for some and found a hadley truck air horn. hoping to win that. just want somethink deep and loud once i get everythink i will post it up as i do it
  #10
Old 20th June 2010
Conductor
Default
Quote:
shockers are your best bet for that.
__________________
2004 Toyota Rav4
Viair 400C
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
