My ride and install - Train Horn Forums
Go Back   Train Horn Forums > Automotive > Your Ride
 Register
Reply
Thread Tools Display Modes
  #1
Old 9th October 2010
MarineOne's Avatar
Moderator
Default My ride and install
So I figured I should get around to this now that I have the pictures.
Here's my ride ..... 2008 Dodge Ram 3500 QC longbed, Cummins 6.7L, G56 manual ..... it's the blue one on the right.
Firestone air bag kit. I had this done at the dealer before I took delivery.
The tank for it was about the size of my 64 ounce 7-Eleven Thermos cup. The lines were run through the firewall into the cab and the dual needle gauge for it failed twice in one year, so I also did an upgrade because I got tired of smelling "bag air". I gutted the old system and went with AirLift's Wireless AIR system ..... it's not fully installed because I ran out of time while from on vacation from Iraq.
Air system on/off switch.
This is a $10 Radio Shack switch just for turning the compressor on or off. I have a small leak that I couldn't fix because I was pressed for time, so this was a good idea. I used the mounting hole for the power pedal adjustment switch because I didn't get this option. It totally looks stock, and the light turns on and off with the switch. I have it run from "key on" power so even if I forget to turn it off, the whole system turns off when the key does.
Interior pics
This is something else I need to work on when I go on my next vacation. Again, I was rushed and I don't like the way it looks so for the sake of cosmetics its going to get re-done.
Exterior pics
I mounted the K3LA to the frame rail on the driver's side. It hangs down a little bit so I had to black it out so that its not very noticeable.
Tank and compressor mounted on the passenger side. The tank is mounted to the bottom of the bed and the comp is mounted directly to the frame rail. It rattles really loud when I fire up the compressor, so I'm going to change the way I put it on there.
Some of this was done by a specialty garage because I didn't have the time to get everything right before I had to leave, and I plan on doing some upgrades next summer for more air and either dual compressors ...... or I might splurge and get an XD3000.
Kris
  #2
Izzy RSL-3LR Izzy RSL-3LR is offline
Senior Member
Izzy RSL-3LR is on a distinguished road
Default Re: My ride and install
  #3
MarineOne's Avatar
Moderator
Thanks!
It's flat bar stock mounted to the frame. You can see the bolts holding it in place in the next to last pic. Up top its bolted to the manifold with a hole for the air fitting.
This and the plumbing were done by the shop, but I had a helping hand: I asked them to run the 1/2 line through the access holes in the cab, and mounted the GW valve to the driver's seat with some 2x2 angle iron from Home Depot. There was no cutting done to the cab to run the lines, just popped out these plastic oval shaped pieces and ran the lines.
Kris
  #4
Old 17th November 2010
CurtisL's Avatar
CurtisL CurtisL is offline
Engineer
CurtisL is on a distinguished road
that horn is beast! haha
__________________
CurtisL
hornblaster shockers at 200psi
ViAir 480c
whelen 100 watt speaker
cobra pa/cb
whelen strobes 90w
interior amber construction LED'S
2 10" MTX SUBS 900 watt kenwood amp
NATHAN K3HA
8.5 GALLON TANK
  #5
Scaredu's Avatar
Scaredu Scaredu is offline
Godfather
Scaredu is on a distinguished road
Send a message via AIM to Scaredu Send a message via MSN to Scaredu Send a message via Yahoo to Scaredu
looks good!!
__________________
2006 VW Passat (Train horns coming soon...)
2004 Chevy Avalanche (SOLD)
Fully Bagged FBSS
Nathan K5LA Airchime Horn
1/2 Airlines and SMC Valves
12 Gallon Tank
Dual 480 Viair Compressor @ 200psi
Whelen WH295SLSA1 Siren/PA
Whelen SA315P Projector Series Speaker 100/200w
  #6
carramerod's Avatar
carramerod carramerod is offline
Senior Member
carramerod is on a distinguished road
Nice job!
  #7
CurtisL's Avatar
Engineer
holy thread resurection batman!!!! haha
__________________
CurtisL
ViAir 480c
cobra pa/cb
whelen strobes 90w
NATHAN K3HA
8.5 GALLON TANK
  #8
Garrett's Avatar
Garrett Garrett is offline
Goatface Killah
Garrett is on a distinguished road
I don't think I have seen this yet! Looks great!
  #9
Old 18th November 2010
Matt's Avatar
Matt Matt is offline
Administrator
Matt is on a distinguished road
Send a message via ICQ to Matt Send a message via AIM to Matt Send a message via Yahoo to Matt
Wow! That's a bad-oven setup you've got there man. I bet it's stupid loud with that Graham White...
  #10
MarineOne's Avatar
Moderator
Heheheheheheh ...... I've been heard at a mile and a half. Don't ask how I found out (I buzzed the fuzz when he was off duty and didn't know it).
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is Off
HTML code is Off
Forum Jump
