Extreme Outback EDC review - Train Horn Forums
Go Back   Train Horn Forums > Automotive > Reviews
 Register
Reply
Thread Tools Display Modes
  #1
Old 23rd August 2011
MarineOne's Avatar
Moderator
Default Extreme Outback EDC review
I finally found a good EDC for the newer diesel trucks out there, bought one, and I don't regret it!
Pictures!
Fill rates on a 5 gallon tank are similar to the Oasis XD series. 0 to 150 psi is roughly 50 seconds at 2000 RPM, or about 80 seconds at idle. My pressure switch is the 145-175 psi version I bought from HB so the fill times are a few seconds more.
Pump is rated to 200 psi, and the kit included everything to get it installed.
Complaints
The install had only one issue; it calls for slightly bending the power steering lines and I didn't like that so I had custom lines made. You can see how the power steering line is run across the top of the battery and that had to go. I'll have one more picture coming of what it looks like with the new lines installed.
__________________
2008 Dodge Ram 3500 QCLB SRW
Nathan AirChime K3LA
Titan Fuel Tank (50 gallons)
Aero Muffler 4040XL
My ride and install
  #2
ear2ear's Avatar
ear2ear ear2ear is offline
Moderator
Default Re: Extreme Outback EDC review
Lucky dog. So are you going with a larger tank at all?
Congrats!
  #3
MarineOne's Avatar
Moderator
I'm upgrading to the 8.5 gallon tank, but ran out of time before I could get the truck bed Rhino-lined and the new tank bolted in. I did get to weld some stand-offs to the tank so that the elbow on the bottom hole of the tank for the drain solenoid won't have clearance issues.
Refill times of around 20 to 30 seconds are normal after a good 3 to 5 second honk, and after fixing some other issues I'm a bit louder now too.
__________________
Aero Muffler 4040XL
My ride and install
  #4
THE BEAST's Avatar
THE BEAST THE BEAST is offline
Conductor
THE BEAST is on a distinguished road
Default
Thats would be nice to have. But I have dual Air Zenith compressors that will be here tommorow
__________________
2001 7.3L Superduty with:
6" Superlift 40" mud grapplers
Road Armor Bumpers
NATHAN AIRCHIME K3HA, K5HA, K1L
Dual AIR ZENITH OB2 compressors
  #5
MarineOne's Avatar
Moderator
Quote:
I was planning to do an Oasis but the batteries, cables, and alternator upgrade made it cost prohibitive.
This is more for getting the information out there ..... and it works on engines other than my Cummins 6.7 .....
__________________
Aero Muffler 4040XL
My ride and install
  #6
THE BEAST's Avatar
Conductor
Default
Yea I like the oasis due to thier high CFM flow but I couldnt say no to Air Zenith they have really nice products and for the CFM vs amp draw betweem Air Zenith, Air Zenith was the better choice.
__________________
Road Armor Bumpers
  #7
ear2ear's Avatar
Moderator
Yeah, an EDC is the way to go if you can hack it. I have dual alternators, so it's not worth trying to make it fit. I have some other silly stuff in the works pertaining to AZ.
  #8
FamCortez1's Avatar
FamCortez1 FamCortez1 is offline
Member
FamCortez1 is on a distinguished road
Why did u have to post this? Now, as soon as my compressor dies out then im going to want this.
Is the power steering lines shown on the pic at risk of damage or did you just not like the position and just want a cleaner look?
__________________
2008 Dodge Ram 2500
Megacab 6.7L Cummins
Road Armor & N-Fab Steps all Line-X'd
35's on Carli front Suspension
K5LA/P3(OC) 8.5-gal 8-port 480C Viair
2008 Ducati Hypermotard 1100S
Full Termignoni Race Exhaust
Race ECU
Weak horn
  #9
Dirty Jersey's Avatar
Dirty Jersey Dirty Jersey is offline
Senior Member
Dirty Jersey is on a distinguished road
Looks good. Saw your posting over on DTR.
__________________
Anything loud and Obnoxious like me.
Dodge 2500 QC Diesel 4x4 LB with a little work done.
To many horns to list.
  #10
Old 24th August 2011
MarineOne's Avatar
Moderator
Quote:
You're on DTR, too? Sweet! Chris (cbrahs) was wanting to see my setup before I left to come back overseas and I couldn't get away from the family the week he was up in my neck of the woods. I needed to get more photos of the install, but with packing and having to fix some big problems with my '06 I just ran out of time.
My '08 is setup to be my tow rig, and I didn't like the way the lines flexed or the way they sat and rubbed the post on top of the battery after having to "bend" the steel lines down by the pump. With towing my toyhauler, the lines would flex even more due to the load and that would lead to premature failure. That's when I went with custom power steering lines which are stronger than what came on the truck, and properly routed.
It also eliminated a problem Dodge has with some of their power steering lines (aka, the hissing issue) on these trucks, which is caused inside the lines themselves.
Like I said, this is more informational than anything. I've been looking for an EDC for a while and wanted to make sure folks not only knew about this product, but the pro's and con's of it, too. I've even seen this kit put on an LS series engine (http://tpiparts.net/inc/sdetail/16933/19872) so I know it'll work for a lot of folks:
__________________
Aero Muffler 4040XL
My ride and install
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is Off
HTML code is Off
Forum Jump
